Unable to insert data into an existing file geodatabase table with "Truncate Existing" setting
  • February 28, 2018
  • 73 views
dilipsebastian
I am trying to create a workflow that would update an existing table in a file geodatabase. It works when i have feature operation set to "Insert" and Table Handling set to "Create If needed" under Format Parameters. When I try to change the Table Handling setting to "Truncate Existing", the workflows fails and errors out
Error:
"Geodatabase Error (-2147220987): The user does not have permission to execute the operation.
FileGDB Writer: A feature could not be written"
Best answer by lottegis
I vaguely recall encountering the same issue. I had to work around it. Try either of these methods.
  • Set Table Handling to "Drop and Create" instead
  • Use a FeatureWriter to perform delete then a second writer to perform the insert with "Create If Needed" or "Use Existing"
lottegis
  • February 28, 2018
dilipsebastian
The second option didn't work for me. I ended up changing my setting to drop and create, although thats not what I wanted to do. My output table is related to another table through a relationship class. Drop and create breaks this relationship class.
