OneDriveConnector User Last Modified
  • December 17, 2019
  • 5 replies
  • 14 views
runneals
Forum|alt.badge.img+22
Is there a way to get the Modified By username/name from One Drive?
Best answer by jlutherthomas
Hi @runneals
Looks like Graph API does support it: https://developer.microsoft.com/en-us/graph/graph-explorer
OneDrive > Recent files > Response Preview
I would recommend using the HTTPCaller if the OneDriveConnector doesn't support it.
"lastModifiedBy": {
                "user": {
                    "email""MeganB@M365x214355.onmicrosoft.com",
                    "displayName""Megan Bowen"
sigtill
Forum|alt.badge.img+24
  • December 20, 2019
Hi @runneals I think you need to use the Microsoft Graph API and check if that has the desired parameters: https://knowledge.safe.com/questions/76488/connection-to-microsoft-graph-api.html
runneals
  • December 20, 2019
I'm using that, but the one drive connector doesn't seem to support it I guess :/
  • December 23, 2019
Hi @runneals
"lastModifiedBy": {
                "user": {
runneals
  • December 26, 2019
jlutherthomas wrote:
Hi @runneals
"lastModifiedBy": {
                "user": {
How hard is it to get integrated to the current OneDriveConnector transformer? That would be ideal if all the attributes came through.
@runneals
We added an option to return the original response of the list request for the List Action in the OneDriveConnector. In the JSON object returned via the new output attribute, you will find the "lastModifiedBy" key.
This is available in FME 2020 b20177 and higher.
