Edit Workbench directly from Microsoft SharePoint
philippeb
Forum|alt.badge.img+20
Hi there,
With all the pandemic story, my organization is accelerating the migration to Microsoft Teams.
They are asking us to migrate almost everything to SharePoint / OneDrive.
I would like to know if there would be a way that I can edit my FMW directly from SharePoint.
Right now I have to download my FMW, edit and repush it to SharePoint. It's kinda ennoying.
Do you have any suggestions?
I'Ve read this below but nothing about editing workspaces.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/sharepoint/sharepoint.htm
Thanks!
philippeb
  • April 20, 2020
OK nevermind. Just found I can connect my SharePoint to Windows Explorer and edit my workbench directly from there.
  • May 8, 2020
How do you do that?
Lets us know how well that works. When I used Dropbox/OneDrive the processes were incredibly slow until I pathed the log files to my C drive.
philippeb
  • May 11, 2020
tforward wrote:
How do you do that?
Easy : here
philippeb
  • May 14, 2020
Honestly we haven't made a ton of test because of a major problem : the path.
I'm new with SharePoint, but right now I can't figure out how to not take in consideration the USER_NAME into the path that point to the file.
If someone else open the workbench or if I run this on FME Server, that path won't work anymore.
For sure, we could use the URL with the domain name. But our root URL is like 500 caracters, I don't want to use that into the scripts. Even that though, I can't make it work...
Anyway, if you have more informations, I'm open! We have the same problem in ArcGIS.
