Loading AutoCAD reader
  • January 26, 2018
  • 45 views
Hello,
I am receiving an error when I try to load an ACAD reader. I have no idea what could be the problem.
Starting translation...
FME 2017.1.2.0 (20171213 - Build 17722 - WIN64)
FME Database Edition (node locked-crc)
Temporary License: 20 days left.
Machine host name is: DESKTOP-7U34IIO
Operating System: Microsoft Windows 10 64-bit (Build 16299)
Copyright (c) 1994 - 2017, Safe Software Inc.
Safe Software Inc.
Creating reader for format: Autodesk AutoCAD DWG/DXF
Trying to find a DYNAMIC plugin for reader named `ACAD'
Loaded module 'ACAD' from file 'C:\\Program Files\\FME\\plugins/ACAD.dll'
FME API version of module 'ACAD' matches current internal version (3.8 20170315)
SOURCE_ACAD Reader: Using rich geometry.
AutoCAD Reader: Error opening file 'C:\\Users\\ddeja\\Desktop\\Projekti\\Bijeljina\\IZVEDENO SAOBRAAJNICA.dwg' during version check
Failed to obtain any schemas from reader 'ACAD' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
FME Session Duration: 0.2 seconds. (CPU: 0.2s user, 0.0s system)
END - ProcessID: 14236, peak process memory usage: 79336 kB, current process memory usage: 41448 kB
Program Terminating
Translation FAILED.
Workspace generation failed. Parameter file was C:\\Users\\ddeja\\AppData\\Local\\Temp\\FME_1516966986688_1408.
This is the error that I am receiving.
Best answer by maliodpalube
I have solved this problem by renaming the file because it had Serbian Latin letter in its name.
  • January 26, 2018
