Hi Guys,
easy question: I want to write an excel file and want to have a sheet for every different attribute entry. (like a fanout)
I haven't find a fanout yet.....how can i do that?
Thx
Franco
Fanout is present in general tab of writer
Hi Franco,
Probably you are using FME 2015.1.
In FME 2015.1, the interface of writer feature type General tab has been changed. The "Fanout By Attribute" has disappeared. Instead, you can select an attribute in the feature type name (Sheet Name) field. It's equivalent to the previous "Fanout By Attribute" setting.
Takashi
Hi guys,
yes I have 2015.1 and it was a little bit confusing becaus ei said to myself..there was a fanout...now its gone....but its solved now.....and I'm not ill and my eyes are healthy ;-))
