Automatic backup
boubcher
Forum|alt.badge.img+11
We want to use FME server in order to copie/backup files , Application , database and store it in safe area , at the oment the task is done manualy , each time system admin will have to go trough all those files , and backup the to the specific location
Best answer by stalknecht
You can create a workspace with a "Directory and File Pathnames"-reader to read the sources and use a "File Copy"-writer to write to another destination.
stalknecht
Forum|alt.badge.img+19
  • January 7, 2018
  • January 8, 2018
I agree. If they need to trigger the actual database backup as well, there's also SystemCaller and the SQLExecutor.
boubcher
  • January 10, 2018
Thanks, Guys Will give it a tray
boubcher
  • January 18, 2018
Thanks guys
any idea how to add the date to the file name, written in the destination folder just to keep track of the backup
alos the overwrite option in writer file copy when set to no , still we are getting only one file
stalknecht
  • January 19, 2018
boubcher wrote:
Thanks guys
If you want dates from the original file then you should set to retrieve file properties.
You must format the dates so it's accepted as a valid filename. (No special characters like +)
If you need the current timestamp you can use the @DateTimeNow() function.
Here is an example:
If you set "overwrite existing file" to NO then it will not make a copy if the file is already there. So this is by design
