Excel - transposed attributes not output in correct order.
  • April 14, 2015
  • 16 views
I am trying to transpose the output of an Excel writer.
I have only 1 row of values to transpose perhaps there is an easier way? e.g
field1, field2, field3
vala, valb, valc
should become
field1, vala
field2, valb
field3, valc
I used the example Transpose2015.fmwt on http://fmepedia.safe.com/articles/How_To/Advanced-manipulation-of-Excel-tables-using-AttributeExploder.
However my output attributes are not ordered.  It appears the incoming order of the attributes is lost when the AttributeExploder is applied?
Is there an easy to resolve this or an easier method to achieve the same?  I had a brief look at the ListPivotDemo but am waiting for the database outage to be resolved before I can test.
Thanks,
Annette
Best answer by pratap
Delete the tester in the "Transpose2013.fmwt" and use it.
Pratap
pratap
Forum|alt.badge.img+11
  • April 15, 2015
Pratap
