How do I connect to a Microsoft SQL Server database using an Active Directory service account?
  • February 19, 2019
  • 171 views
The SQL Server database I'm connecting to won't support database authentication (policy), so I got a AD service account created, but I can't find an option where I can use Windows Authentication, but I can still enter in the credentials (they are greyed out when you choose Windows Authentication).
FYI: I'm using FME 2018.1
  • February 20, 2019
The Active Directory Authentication uses your current windows user account, so the user a password are disabled in the connection parameters. FME SQL Server reader/writer help - see under Authentication
