How can i store _packed attributes which is having multiple attributes packed by AttributejSonPacker?
Can i store that _packed attribute as BLOB type attribute in File Geodatabase?
Thanks in advance.
Thanks in advance.
Best answer by david_r
Here's a small workspace that demonstrates reading and writing JSON-packed attributes to a text attribute in a file geodatabase.
Disable either one of the bookmarks to test either reading or writing to the fgdb (don't leave both enabled).
