How do I create a summary table of all points inside specific polygon geometries?
Hi All,
What I am trying to achieve is a Spatial Join of all points which fall inside a specific polygon and then summarise these like a cross tab against each electoral ward area. So far, I have found the SpatialRelator and Statistics Calculator to try and achieve this.
Can anyone suggest a better method of point me in the right direction?
Thanks,
Gary
  • June 27, 2013
Hi Gary,
I think the SpatialRelator is a good choice. If polygons are not overlapped each other, the SpatialFilter generates the same result and might be more efficient.
Takashi
  • June 27, 2013
Hi Gary,
how about something like
  • PointOnAreaOverlyer to give each point the ID of their respective polygons
  • Send the points to an Aggregator with a Group By on the polygon ID. Also specify a list name.
  • Run a ListHistogrammer on the list specified in the Aggregator to get the number of occurances in each category, per polygon.
Hopefully this gives you some ideas.
David
  • June 27, 2013
Hi David/Takashi,
Thanks for the replies.
So there are at least 'two ways to skin a cat!', so to speak.
Gary
fmelizard
Forum|alt.badge.img+18
  • June 27, 2013
There are probably more ways for the cat to die :)
You could also use the clipper for that, but the underlaying story is getting the relationships between the objects built. once that is done then there are plenty of ways (too) to analize and visualise it.
  • June 28, 2013
Hi Itay,
According to Schrödinger, that is very true.
Thanks all for your help!
Gary
