center line between parcel
Dear All ,
How to find the center line between parcel , we trying to build a walkable path between parcel so we need to find the center line. we got the area between the parcel using area on area , but then how to get the center line of the out come, we checked center line replacement but it does not work
fmelizard
Forum|alt.badge.img+18
  • January 5, 2015
Hi Khalid,
From my experience the CenterLineReplacer wont work as expected with complex geometries, this is also stated in the help: 'This transformer works best with long, narrow areas.'
I would try and create smaller narrow areas to get a reasonable center lines that can later be joined.
Itay
gio
Forum|alt.badge.img+15
  • January 6, 2015
You can create lines form the parcels and then explode them to linepieces.
Then calculate the intersections of the lines in incremental steps.(1m, 2m etc.).
This then results in a network of lines.
You can, for instance. overlay this network on the "between parcels" area.
This would result in the areas between parcels, but in smaller (mostly rectangular)sections wich you can use the centerlinereplacer on.
Resulting centerlines can then by joined.
