Released
FME Server Automations - Send an Email Action with multiple attachments
danielleatsafe
  • danielleatsafe
    danielleatsafe
sameer
mattmatsafe
Forum|alt.badge.img+13
  • August 25, 2022
Update: as of FME Server 2022.1, it is now possible to attach multiple files when using the Email Action
pmcpherson
Forum|alt.badge.img+9
  • September 19, 2022
Matt,
Is there a trick to getting the multiple attachments to work? I tried same with a random Automation and it did not work.
2022-09-19_10-20-47
mattmatsafe
Hi @pmcpherson​ , you need a space between the key values: {route.reconciliation_dataset} {route.raw_dataset}
pmcpherson
  • September 20, 2022
Matt,
I eventually got this to work by adding double quotes around each item, AND a space between them, from the text editor option. This was not exactly straightforward because when viewed after-the-fact, the double quotes are no longer visible.
2022-09-20_7-50-49Regardless it seems to be working now but I can see how this might cause some confusion for other users.
