FME Data inspector background map parameters won't open
Hello,
I'm trying to set up a background map for Data Inspector and when I select a Background Format, the parameters button won't open.  Has anyone else experienced this?  I am using the ArcGIS Data Interop Extension (10.3.1) and not a full FME license.  Is that the issue?  Please help - would love to set a background map.
Thanks!
-Steve
Be the first to reply!
