change feature orientation from left to right hand rule
harmen_kampinga
In a multipatch there is a feature with polygons who do have a Left Hand Rule orientation.
I like to change that to the Right Hand Rule orientation.
How should that be done?
Example:
andreaatsafe
Forum|alt.badge.img+10
Hi @h1,
Have you tried the Orientor transformer?
I think this may help you with what you are trying to achieve.
- Andrea
harmen_kampinga
Thank you Andrea,
I've done that indeed, but unfortunately not with the desired results.
I'll have a look at it again.
grtz,
Harmen
