Currently the copy number (_copynum) created by the Cloner always starts from 0. In some cases, the copy number will be used for parameters in the following transformers and there are cases it has to be a 1-based number. Although it's easy to increment the number, it might be better that the user could specify the starting number as a parameter of the Cloner, as same as the Counter.
