I'm setting up a dev server and wanted to import a certificate. I followed the steps but when i import keytool -import -alias tomcat -keystore tomcat.keystore -file <name> I get an error "signed fields invalid". Also, because the IT Contracting agency manages the certificates they applied it to the server i needed to export the PFX file to use in the keytool script. Any thoughts???
https keystore certificate error signed fields invalid.
Best answer by jlutherthomas
Update for this question:
Through direct support the HTTPS/SSL configuration got to a nearly good place, with the FME Server web ui working, but jobs wouldn't run: 'Error submitting the job'.
In the tomcat localhost log we identified a pkix path building error.
In order to resolve this issue, we configured FME Server using the steps in this article, put together to help any other users who may be importing pfx certificates.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
