I have a simple FME 14 workspace that transforms a Sybase table into an ESRI gdb table with the option that the Writer uses the attributes from the Reader (Copy Attr. From Feature Type). all worked well.
Now I added a AttributeRenamer to change the name of some (not all) attributes. That leads to a resulting table where all (renamed and unchanged) attributes are chars with length 200.
So, how can I tell the Renamer only to re-name and not to change the data type ?
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
