I want to perform a spatial intersection of two polygon features to determine values.
  • November 9, 2015
  • 8 views
I have a SQL script that does the job but it takes too long (over 20 hours). I am hoping FME can perform better. Script is below:-
select Land_No, PropNum, Property_Address,b.SCHEME_CODE, b.ZONE_CODE, p.Geometry, p.SP_Geometry,
ROW_NUMBER()OVER(PARTITIONby p.Land_No ORDERBY p.Land_No)AS Dup
INTO CI_Plan_Zone
from LandVic.dbo.PropParcelOwner p, [External].dbo.PS_Zone b
where p.SP_Geometry.STIntersects(b.Geometry_SPA.STBuffer(-0.1))=1
regards
Phil
  • November 10, 2015
Hi Phil,
I'm not sure which is more efficient, the SQL query or FME transformers, but think the Bufferer and SpatialRelator can be used to get the same result as the query.
Takashi
