Schema based GML Writer
  • September 9, 2015
  • 8 views
Hi all,
At the moment, I have workspace using XMLTemplater to make desired GML, and after that sending it to text writer to write a file. I saw that there is GML writer that supports user specified schemas. Does someone has an workbench example using this writer? I want to read data from SQL Server Non-Spatial stored procedures and, after transforming them, write them into GML file.
Thanks!
Best answer by takashi
I myself have no experiences about using the GML writer with a specific application schema, but here is an example.
GML Writing with Application Schemas (https://knowledge.safe.com/articles/How_To/GML-Writing)
If your purpose is to validate the GML document based on a specific application schema, I think the XMLValidator can also be used.
Takashi
  • September 10, 2015
Takashi
