FME Server 2017 not picking up ArcMap 10.5.1 license - FME Desktop works ok
annette2
Forum|alt.badge.img+10
We upgraded from 2015 Server to 2017 on our test server. Desktop picks up the ArcMap 10.5.1 license. I can open ArcMap on the machine.
But FME Server 2017 does not recognise the license. I test with a simple write to a local file geodatabase and I get the following below.
Any ideas how to get Server 2017 to recognise the ArcMap license?
Thanks,
Annette
Writer `GEODATABASE_FILE_1' of type `GEODATABASE_FILE' using group definition keyword `GEODATABASE_FILE_1_DEF'
FME API version of module 'GEODATABASE_FILE' matches current internal version (3.8 20170315)
The ArcObjects license 'Basic' is being selected from the Windows registry
The Esri Product license used by this machine does not include licenses for the 'Basic' licensing level
Unable to perform licensing related tasks. Please ensure that ArcGIS is correctly installed
Closing the Geodatabase writer
Feature output statistics for `GEODATABASE_FILE' writer using keyword `GEODATABASE_FILE_1':
Features Written
Total Features Written 0
  • February 1, 2018
We've seen something similar with one of our clients. After much back and forth, including Safe support, we were able to pin the error to a recent Windows 10 security update.
You may want to run the system information batch file provided by Safe and forward it to your FME reseller so they can work with Safe and see if it's the same issue: https://knowledge.safe.com/articles/714/general-troubleshooting-gathering-system-informati.html
annette2
  • February 1, 2018
Good idea. It is in fact a Windows 8 test machine. We will run this and send to Safe. We are setting up a proper test server but the machine isn't ready yet.
annette2
  • February 1, 2018
Tried another virtual machine with the same OS and it is working :)
