Read Model Space Entities Through Viewport
deanhowell
Forum|alt.badge.img+23
Is there a way to use both parameter options with a DWG, i.e. Read Model Space Entities Through Viewport - Yes and Read Model Space Entities Through Viewport - No?
I have some features, like text, that need to be tested for text height and thus need the 'Read Model Space Entities Through Viewport' set to 'Yes' as this will give me the paperspace size for the entities.
If I have the 'Read Model Space Entities Through Viewport' set to 'No', I can test the features that are only in either paperspace or model space but can get the paperspace text size for through features displayed through a viewport.
Any suggestions on how I can determine what is only in model space and only in paperspace but get the paperspace size for all features?
Be the first to reply!
