fmw files cannot be opened after switching to a floating license
I had fme desktop 2018 with a fixed license, then i switched to fme desktop 2019 with a floating license, and now i can't open my old fmw files.
Once i try to open an old fmw file it gives me an error : File cannot be opened : user may not have sufficient privileges to read the file. (but i still can lunch fme dekstop).
Any ideas ?
Thank you,
Soukaina
Forum|alt.badge.img+49
Are you sure that's the only thing that's changed? It's just that the error doesn't seem to have anything to do with moving from a 2018 fixed to 2019 floating license. Any chance network permissions have changed?
  • November 21, 2019
Yes it's the only thing that has changed even since.I have all the required permissions and control over everything.
fmelizard
Forum|alt.badge.img+18
  • November 22, 2019
Hi @soukaina If you can repro this problem then please send your workspaces and details to https://www.safe.com/support/report-a-problem/
