hi
I am trying to compare two datasets by calculating the CRC value for (building number , streetname , suburb name) for each of the datasets and running through the feature merger (unreferenced port) to pick up new updates .
This has picked up quite a few records that already exist . the building number could be like 37-39 or 25A etc . Can the CRC calculator handle this ?
