Water body into LnadXML
Dear FME Users,
I want to write water body inbto LandXML together with DTM TIN surface. I have the water defined as closed polygons. How do I do it? Should I triangulate the water polygons and save as another surface/s?
What about watershed feature (not supported by LandXML writer I believe)? or should I write the water body as polygon/s. Any advice would be appreciated.
Thank you.
barani
Be the first to reply!
