Is it possible to add transfomer with PC sound notification? Eg. If unexpected path event was detected or a scound notification to the data inspector new window opening?
Best answer by david_r
If you're on Windows, you can use two lines of code in a PythonCaller, e.g.
import winsound
winsound.MessageBeep()
This will trigger the sound file that is associated with the "Default Beep" event in the Windows sound settings:
imageMore info here: https://docs.python.org/3/library/winsound.html
nielsgerrits
You can set sounds under Tools, Options, Appearence, Advanced Options, Configure Sound Events...
If you need more specific / custom stuff you can use a SystemCaller to start anything you want :)
  • March 27, 2023
import winsound
nielsgerrits
import winsound
import winsound
class FeatureProcessor(object):
    def input(self, feature):
        frequency = 2500 # Set Frequency To 2500 Hertz
        duration = 100 # Set Duration To 1000 ms == 1 second
        winsound.Beep(frequency, duration)
        self.pyoutput(feature)
Working sample for the not Python experts like me:)
jkr_wrk
Forum|alt.badge.img+28
  • March 27, 2023
nielsgerrits wrote:
import winsound
Let's delete the default comments and keep the default functions.
This script plays a different sound (length) when groups exit the transformer, so it sounds like morse.
import fme
import fmeobjects
import winsound
    freq = 2000
    duration = 100
    groupfreq = 2000
    groupduration = 300
    def __init__(self):
        pass
        winsound.Beep(self.freq,self.duration)
    def close(self):
        pass
    def process_group(self):
        winsound.Beep(self.groupfreq,self.groupduration)
jkr_wrk
  • March 27, 2023
nielsgerrits wrote:
import winsound
And the most minimalist version that works:
import winsound
def FeatureProcessor(feature):
    pass
Because you have to set a Class or Function to Process Features. And this Class or Function has to accept the 'feature' object.
But be aware that this only plays sounds if you have your system sounds enabled.
Else the Beep(2000,100) and not the MessageBeep() would be the way to go.
  • March 27, 2023
Thank you.
  • March 27, 2023
nielsgerrits wrote:
import winsound
Lol, I think you should create an idea for a MIDI file reader ;-)
