Hi folks,
This is my first post here so apologies if this is a basic question. I have a quick one about a workspace runner operation I am using. I have a project that makes sense and is working but I'm looking at trying to make it more efficient.
It takes 2 files, workspace runner passes it file A, the workspace runs and matches variables in A to another static file, file B. then outputs the resulting file in File C. This all makes sense. It works beautifully.
However it would be nice if I could read file B once as oppose to every time the work space runner fires off a process. It's a static file and quite big, and I have about 17,000+ file As to process, loading in File B for each of these is a massive drain on time.
Is it possible to 'preload' a file for a workspace runner? I've looked everywhere for an answer but not seen anything that leads to an answer.
