Parallel processing question
Forum|alt.badge.img+48
@NatalieAtSafe Could you please get somebody from support or development to take a look at this: https://knowledge.safe.com/questions/70983/parallel-processing-doesnt-start.html
We're running in to this during a training course, the only noticable difference between his computer and mine is that he's running Windows Pro and has had to re-install everything about a week ago after a failed update.
fmelizard
Forum|alt.badge.img+17
  • May 24, 2018
Hi @redgeographics,
Thank you for letting me know. I'll ask someone from support to investigate this issue.
fmelizard
  • May 25, 2018
Hi @redgeographics.
Is the issue for you also related to whether Run with feature caching is disabled?
Yes, same customer
