I've used a method in the past with a WorkspaceRunner to pass a timestamp value into the log file name parameter of a second workspace to ensure that I always get a unique logfile for each rn of the same workspace. But, that's only any good when I can trigger the process in this way. Right now, what I want to be able to do is to use a scripted parameter ideally to generate a unique log file name that is say a concatenation of the workspace name and the start time so like: FMEBatchRun_2014-03-12T12:01:52.log.
Is a scripted parameter the best option for this and if so, can anyone help me with the syntax as I'm not much good (any good really) at writing python...
Thanks, Dave
