Anyone have any experience with converting GTFS data to shapefile (lines and points) in FME. Or any other method available.
Regards,
KDMUR
Regards,
KDMUR
Best answer by fmelizard
Cant say I have any experience in converting GTFS data, but after having a quick look at it its mainly a question of reading the txt\\csv files, transforming the shape text file into points or lines (2D point replacer + point connector) and combining the attributes.
Optionally you can import the shape text file into excel and use the new functionality of the xls reader (SP2) to read features coordinates directly.
Itay
