oracle raw data type cannot be translated
Hi Everyone,
I'm trying to translate an table in one Oracle database to another Oracle database. From production to development for this case. The problem is that FME will not write a RAW Oracle datatype.
This appears to be intended functionality since the message I get from the FME log is "Oracle Reader: Skipping column '<column_name>' of Oracle Spatial layer '<schema.table>', which is reporting a data type of 'RAW' "
Can anyone give me some insight into wether this is intended functionality or if it is buggy?
Best answer by david_r
FME doesn't support Oracle RAW datatypes, at least up to and including FME 2014 SP5. You will therefore have to manually cast these datatypes to e.g. VARCHAR2, as described in the answer that Itay linked to.
It seems that RAW support has been added in FME 2015, but I haven't tested it yet.
David
fmelizard
Forum|alt.badge.img+18
  • January 6, 2015
Possibly this answer can be of use to you:
https://safecommunity.force.com/CommunityAnswers?id=906a0000000clfIAAQ&s=2&
  • January 6, 2015
David
