FME Server API and Data Upload
  • August 20, 2018
  • 25 views
ld
Participant
  • Participant
Hi
I have a workspace on FME Server (Cloud) which currently uses the data download service. It requires the user to upload a .csv and a .pdf, then it runs a translation and delivers a .kmz and a folder of geoTIFFs.
I'd like to run this workspace using a call to the REST API. I'm struggling to figure out how 2 files can be uploaded as part of the same SUBMIT call. Assuming I can do this, will the call still trigger a data download? Or will I need to write to a shared resource folder?
Any help appreciated, thanks.
Best answer by stalknecht
See the following examples:
https://playground.fmeserver.com/javascript/server-uploads/upload-file-in-session/
and
https://playground.fmeserver.com/javascript/server-uploads/upload-file-drag-drop/
good luck!
