FME 2017.0 Emailer issue: C125117 (PR76958)
Forum|alt.badge.img+19
Hi @NatalieAtSafe,
From this Q&A;: SMTP error
The issue has been filed as C125117 (PR76958) and I was notified that it has been fixed in FME 2017.1 Beta already. I confirmed that the original issue has been resolved in FME 2017.1 Beta with Python 3.5, but the fixed Emailer newly causes this error when running with Python 2.7. I think the error apparently indicates that the implementation of the Emailer in FME 2017.1 Beta doesn't conform to Python 2.7 specifications.
Emailer: <type 'exceptions.TypeError'>: character mapping must return integer, None or unicode
Nearly two months have passed since I reported the error above, but it has not been resolved yet in the latest Beta build 17498.
Could you please check the current status of the PR?
Best answer by stephenwu
Thanks for finding and checking in on this @takashi! A fix has been submitted and should be available in the FME 2017.1 Beta build 17503.
fmelizard
Forum|alt.badge.img+17
  • June 4, 2017
I've also escalated to Swu
  • June 7, 2017
  • June 7, 2017
Thanks for your efforts to investigate and fix the issue, @stephenwu.
  • June 8, 2017
I confirmed that the issue has been resolved in FME 2017.1 Beta build 17503.
Thanks again.
