FME ingore the multipart polygones
wind
I work with WFS reader with polygons and multipart polygons. So, FME ingore the multipart polygones. There is no any error message, but it imports only simply polygons. I don't understand why. Is there any parameter of the WFS reader to change?
Thanks
Best answer by nielsgerrits
The database behind the service might have to update the extents of the featureclass. When you add a big boundingbox to the query it works:
https://carto.sigena.fr/cgi-bin/mapservwfs?&service=wfs&version=2.0.0&request=getfeature&typenames=n_enp_apb_s_r75&BBOX=-9589968,-3586633,10633187,16635814&resulttype=hits
numberMatched="78"
If you add this boundingbox in FME it returns 78 features as well:
readwfs2018.fmw
Found in QGIS when the checkbox "Only request features overlapping the view extent" was marked and zooming out I got more results.
fmelizard
Forum|alt.badge.img+18
  • January 26, 2019
Can you provide the URL of the WFS to It definitely should work but we'd need information to understand why you're seeing what you're seeing. Sorry for this.
wind
  • January 28, 2019
Hello,
Thank you for your answer.
For more Information, the WFS is
https://carto.sigena.fr/cgi-bin/mapservwfs? The table "n_enp_apb_s_r75 {n_enp_apb_s_r75}"
FME see 56 polygons
QGIS see 78 polygons.
FME ignore the multipart polygons in WFS and in shp files also.
Thanks
Best regards
nielsgerrits
Forum|alt.badge.img+54
wind wrote:
Hello,
FME see 56 polygons
Thanks
Best regards
If I query the service, it returns 56 results:
https://carto.sigena.fr/cgi-bin/mapservwfs?&service=wfs&version=2.0.0&request=getfeature&typenames=n_enp_apb_s_r75&resulttype=hits
numberMatched="56"
What version of QGIS do you use? I checked in 3.4.2 and it resulted in 56 features as well.
But QGIS 2.18.19 counts 68 features...
Forum|alt.badge.img+35
  • January 28, 2019
numberMatched="56"
Yes, I see the same 56 in both QGIS and FME. There are multipart polygons within those 56 (can deaggregate to 72 features)
wind
  • January 28, 2019
numberMatched="56"
I use QGIS 2.18.13
But in FME DATA INSPECTOR you see:
In the pictures you can see that FME Data Inspector miss à lot of polygons.
Also, in the table of QGIS you can see "Total entités 78". But in FME Inspector 56.
nielsgerrits
  • January 28, 2019
numberMatched="78"
readwfs2018.fmw
wind
  • January 28, 2019
numberMatched="78"
readwfs2018.fmw
It works!!!
Thank you very much!
