Using published param value in FME Server output filename
nic_ran
Forum|alt.badge.img+16
this question has been asked previously in the old forum but I couldn't find any answer.
I have a workspace that writes an Excel file. The destination dataset uses the value of a published parameter to set the output filename.
e.g.
DEST_DATASET = $(PROSPECT).xls
When running the workspace on the desktop the replacement works as expected. e.g. the output filename becomes "my_prospect.xls".
When the workspace is published up to FME Server (2013 sp2) as a data download service the workspace runs but the XLS file returned inside the .zip file is called "$(PROSPECT).xls". ie. no parameter substitution is occuring.
Does anyone know how to do this?
thanks,
Nic
nic_ran
  • May 28, 2013
Forgot to mention.
If I use the Job Submitter service then the parameter substitution works as expected. It's the Data Download service that I can't get to work...
nrich_defra
Forum|alt.badge.img+5
  • May 29, 2013
Hello,
I had the same problem but asked the question in a different way.
Didn't find a solution for the problem you are describing, but  I did find a way to create a dynamic filename in a workbench registered with the data download service, which is perhaps what you are trying to achieve?
https://safe.secure.force.com/AnswersQuestionDetail?id=906a0000000clIkAAI
Regards,
Nick
nrich_defra
  • May 29, 2013
2nd attempt using the hyperlink button in the editor...
nic_ran
  • May 29, 2013
I guess I should have tried things out before claiming they wouldn't work!
The fanout dataset option on the writer did the trick. This FMEPedia article helped:
http://fmepedia.safe.com/articles/Error_Unexpected_Behavior/FME-Server-Workspace-Fails-to-Write-Data
If the attribute to fanout on has just a single value, then only a single file will be written and the feature types will still get their seperate tabs in the resulting Excel spreadsheet.
  • May 22, 2023
Ten years later, I ran into the exact same problem and managed to solve it with Fanout Dataset! :)
