Please help, at a complete loose end. I have a process that's copying data from one SDE database to another. So far it's working almost okay. My main problem is a featureclass which uses multipoint geometry, and I'm dynamically setting the geometry on the writer (intended as this process will be a child workspace run against different datasources). The only way I could initially get it to work was to tell it to set the geometry based on the first feature, but I have one dataset that has 4-5 multipoint features towards the end of the dataset, so the process bombs out trying to put an aggregate into a simple feature type.
HELP: Detecting aggregate features and setting writer type
Best answer by davideagle
How about using an AggregateFilter or a PartCounter and a Tester to filter off the multi-part features and either Deaggregate them, throw them away or route them to a separate FeatureClass?
