Listpopulator with 2 prefixes
p.jeremie
I don't really know how to solve my current issue.
Context
I have data as follow :
IDCIS1CIS2CIS3TPS1TPS2TPS30001AMACHLLOR780102414200002LIVAMARBN681702895..................
The TPS columns are times in seconds.
I need to add a delay to these times regarding the corresponding CISX value (e.g. add 1000 when CIS is 'AMA', add 1500 when CIS is LOR...).
Then I need to sort the values to get the quicker CIS regarding to the TPS time with the delay added.
Ideas
To do that I think that putting all my CIS and TPS in a list with two attributes can help me, but I can't find how to do it.
What I think I need to have as a first result (to start manipulating my data) :
ID0001List{0}.CISAMAList{0}.TPS780List{1}.CISCHLList{1}.TPS1024List{2}.CISLORList{2}.TPS1420
I tried with the ListPopulator, it works fine if I give it CIS as prefix I get my list but of the CIS only.
I can put two ListPopulator, one with CIS as prefix then one with TPS as prefix, but I get two different lists.
How can I create a single list with 2 attributes in it (CIS and TPS) ?
Any other ideas ?
If you think about other ideas to handle my need (add delay, sort and get quicker CIS), please tell me !
Best answer by takashi
Hi @p.jeremie,
I have two ideas:
BulkAttributeRenamer with Regular Expression Replace mode
JSONTemplater and JSONFlattener
Template Expression
    "List" : [
        let $c := fme:get-list-attribute('CIS{}')
        let $t := fme:get-list-attribute('TPS{}')
        for $i in (1 to count($c))
        return
            "CIS" : $c[$i],
            "TPS" : $t[$i]
erik_jan
Forum|alt.badge.img+17
  • August 1, 2019
Have you tried using the ListExpressionPopulator
You could use a regular expression ^[CIS|TPS] for the right attributes.
Hope this helps.
p.jeremie
  • August 1, 2019
Hope this helps.
I tried with the regexp ^CIS|^TPS (which doesn't produce the same result as your regexp strangely...).
But the result is not as expected, I have a list with the 6 values like this :
ID0001List{0}AMAList{1}CHLList{2}LOR
List{3}780List{4}1024
List{5}1420
erik_jan
  • August 1, 2019
Hope this helps.
And how about using the AttributeManager, renaming CIS1 to List{0}.CIS , TPS1 to List{0}.TPS and so on.
This only works if the source attributes are always the same.
Forum|alt.badge.img+19
  • August 1, 2019
Hi @p.jeremie,
I have two ideas:
Template Expression
    "List" : [
        return
            "CIS" : $c[$i],
            "TPS" : $t[$i]
Forum|alt.badge.img+31
  • August 1, 2019
How is the information on what figures are needed to be added for each letter combination stored, and how many are there?
p.jeremie
  • August 1, 2019
takashi wrote:
Hi @p.jeremie,
I have two ideas:
Template Expression
    "List" : [
        return
            "CIS" : $c[$i],
            "TPS" : $t[$i]
@takashi I like your BulkAttributeRenamer solution ! In the meantime I used the ListZipper transformer to achieve my goal but I prefer this solution. Thanks a lot.
p.jeremie
  • August 1, 2019
@egomm The delay to be add are in a xlsx file with the key CIS and value in a Delay column.
CIS
Delay
AMA
1000
CHL
700
LOR
1500
LIV
1000
RBN
300
For the moment my solution is to explode the list I created and perform a FeatureJoiner on the CIS key. This way I can create a new attribute TPSnew = @Evaluate(@Value(TPS)+@Value(DELAY))
I still have to sort and re-create my CIS1, CIS2... columns.
  • August 1, 2019
CIS
Delay
AMA
1000
CHL
700
LOR
1500
LIV
1000
RBN
300
I'd probably use a python caller to create a list.
But if you're using python anyway, I'd try and do the addition as well, to avoid having to explode and recombine
import fme
import fmeobjects
def processFeature(feature):
    lookup = {'AMA':1000,'CHL':700,'LOR':1500,'LIV':1000,'RBN':300}
    tpslist = []
    for i in range(1,4):
        cis = feature.getAttribute('CIS'+str(i))
        tps = feature.getAttribute('TPS'+str(i))
        newtps = tps + float(lookup.get(cis))
        tpslist.append((i,newtps))
        feature.setAttribute('NewTPS'+str(i),newtps)
    lowest =  (min(tpslist, key = lambda t: t[1]))
    feature.setAttribute('lowest','TPS'+str(lowest[0]))
Which would give you this sort of output
p.jeremie
  • August 2, 2019
import fme
import fmeobjects
    tpslist = []
@egomm Thank you for your proposal.
Can you explain me the part below ?
lowest =  (min(tpslist, key = lambda t: t[1]))    feature.setAttribute('lowest','TPS'+str(lowest[0]))
And how can I use my Excel data of the "Delay table" in the PythonCaller ? I saw you put them in a lookup dictionary but I don't know how to recreate it...
In fact, to simplify I said I need to get the quicker TPS, but in reality I need to sort all my CISx with their new time.
So I need to have this result :
Start Table
IDCIS1CIS2CIS3TPS1TPS2TPS30001AMACHLLOR780102414200002LIVAMARBN681702895.....................
Delay table
CIS
Delay
AMA
1000
CHL
700
LOR
1500
LIV
1000
RBN
300
New Table (underlined CIS have change place with the time sort)
IDCIS1CIS2CIS3newTPS1newTPS2newTPS30001CHLAMA
LOR1724178029200002RBNLIVAMA
119516811702.....................
I assume it can be quicker/more efficient to to all this in python but I don't know how to do it as I'm not used to code python.
And I'm wondering if this kind of processing is stable on a long term (new versions of python). Is it not better to used fme transformer to ensure that my workspace will continue to work well ? i would appreciate any advice on this subject.
p.jeremie
  • August 2, 2019
Good idea, I didn't know it was possible to do so.
But I prefer the takashi solution. Thanks anyway !
  • August 2, 2019
Start Table
Delay table
CIS
Delay
AMA
1000
CHL
700
LOR
1500
LIV
1000
RBN
300
I generally work on the idea that if something can be done in fme in less than 5 transformers, I'd choose that over a python solution (with some exceptions for certain things where python is just much faster).
What you are trying to achieve is to me much more straightforward to do in python than in FME (and i only dabble in python in FME, i'm not an expert)
The last bit of the python is finding the minimum value of your new TPS values, and writing that to a new attribute. If you actually want the CIS2 to become CIS1 and TPS2 to become TPS1 based on values you need a slightly different process
  • August 2, 2019
I've attached a template file that will create your NewTable
import fme
import fmeobjects
    #dictionary of lookup values
    #create list
    tpslist = []
        #add delay to tps based on cis value
        #add values to list
        tpslist.append((cis,newtps))
    #sort list in ascending order by second item in tuple
    tpslist.sort(key=lambda tup: tup[1])
    #step through ordered list and create new attributes named in same order as list
    for i,(cis,newtps) in enumerate(tpslist):
        feature.setAttribute('CIS'+str(i+1),cis)
        feature.setAttribute('NewTPS'+str(i+1),newtps)
list_populator_community.fmwt
@p.jeremie updated template with lookup from excel
p.jeremie
  • August 2, 2019
import fme
import fmeobjects
    #create list
    tpslist = []
        #add values to list
Great !
Now I need to find how can I use my Excel data of the "Delay table" in the PythonCaller. I saw you put them in a lookup dictionary but I don't know how to recreate it...
  • August 2, 2019
p.jeremie wrote:
Great !
Does the lookup table change?
p.jeremie
  • August 2, 2019
Yes it can change (keys and delays)... That's why I can't write it raw in the PythonCaller.
  • August 2, 2019
I've updated the template with an example of how you could do this - it's probably not the most efficient but it works
