FME doesn´t accept my ArcGIS 10.3.1 Installation as being current
  • January 23, 2017
  • 4 views
When creating a lasd file with fme I get the following error although I have ArcGIS Desktop 10.3.1 installed
"FME has checked out an Esri license. The product checked out is 'ArcInfo' LAS writer: ArcGIS 10.1 or newer is required to create an ArcGIS LAS Dataset. No ArcGIS LAS Dataset will be created. LAS files produced by the FME LAS writer have not been affected"
Is there anyone who has defeated this error?
  • January 26, 2017
You need ArcGIS 3D Analyst extension and an appropriate license to create the Esri ArcGIS LAS Datasets
