Data download URLs returning localhost
The data download service on our FME server has started to return URLs with http://localhost:8080 instead of the server name. I can correct the URL in my app, but I'd rather get the service to return a correct URL.
I remember seeing an article about how to change the download URLs back for Server 2012 but I can't find it now. Where do I find the settings for changing the URL?
(I've already tried changing the URL pattern in the services settings).
Thanks!
fmelizard
Forum|alt.badge.img+17
  • July 25, 2013
Hi AndyE,
In the WebUI for FME Server go to the Services page then click on Data Download. You can change the "URL Pattern" there.  I think that should do it.
Ken
  • August 9, 2013
Hi Ken,
Tracked the issue down to a missed step in setting up IIS as a reverse proxy, we hadn't set the ResultPrefix in the engine config files:
http://fmepedia.safe.com/articles/How_To/Use-a-reverse-proxy-with-FME-Server
All is now well!
Andy
