Oracle connection warning in FME Job log
  • October 10, 2018
  • 37 views
I got a FME work space (version 2017) published into Server and scheduled to run every half an hour.
I have got an oracle connection parameters published into FME server
Within the work space i've got several transformer for example
SQL Creator,SQL Executer,DBJoiner and DatabaseUpdater - all of them are using the same oracle DB connection.
But some of them are Persistent connection and some are not ( Actually i thought it won't make any difference in the process)
But i am seeing the below warning messages in my FME Job log
WARN |Existing connection changed to 'persistent' mode (is connection closed after all clients release it) setting. The following connection is being requested in an inconsistent manner (serverType='ORACLE8i', serverName='***', userName='***', password='***', dbname='')
0.0|WARN |Existing connection changed to 'non-persistent' mode (is connection closed after all clients release it) setting. The following connection is being requested in an inconsistent manner (serverType='ORACLE8i', serverName='***', userName='***', password='***', dbname='')
How could i avoid these warnings in my log?
Any help would be much appreciated.
Thanks in advance,
Mari...
  • October 31, 2018
Hello Mari,
I also found same warning in one of my FME job.
Were you able to find root cause?
Thanks in advance.
Vikas
  • November 16, 2018
Hello Mari,
Thanks in advance.
Vikas
Hi Vikas,
No not yet.I am still waiting for a clue :(
Regards,
Mari...
richardatsafe
Forum|alt.badge.img+10
Hi @reachmj,
As you noted this this warning is caused by the fact you have persistent and non-persistent connections in the same workspace. While normally this is not a concern as an open non-persistent connection will be shared between transformers. For instance if one transformer has not fully closed the connection before the next one begins.
The warning is a concern under the following circumstances, and assumes that you do not want to open a new connection.
Within a workspace:
A reader or transformer is set to a non-persistent connection and it finishes reading and closing the connection. The following transformer will use a new connection.
On FME Server:
Since persistent connections exist on fmeServer until an engine restart. If the last connection to use the connection is a non-persistent connection the following workspace will create a new connection.
So to avoid the errors I would try setting the connections to be the same. (Persistent / Non-Persistent).
Richard
