I have set up an automation process that retrieves information from an API to generate a report. However, this task has become complicated because an essential piece of information we need to include in the report is located in a different API, which requires an ID to access the relevant data.
I am considering generating the report first, which will consist of the necessary IDs. Then, I plan to make a second API call to retrieve the information from the second API, one ID at a time. I have successfully completed the first part, but I am now stuck on the second part and unsure whether this can be achieved using FME or if a Python script is the only solution.
