Hello,
I am struggling with a similar problem as this post (I think?). One of my attributes in the Workspace contains a 0 or 1 that is used as a Boolean. The value has been assigned the datatype ‘buffer’ in AttributeCreator and ‘string’ in the FeatureWriter, which outputs an Excel file. I am using a template, where the cell format is set to ‘General’.
For some reason, the Excel file that is generated will give me inconsistent formatting of the attribute value:
As you can see, even though they all should be interpreted as strings, some of the values become numbers. The formula bar does not show anything different. I started using the Excel template in hopes of making the data format consistently, but even when I changed the cell format to ‘Text’ it still gave me issues when being read by Python.
I would like to solve this issue before reverting to a Yes/No or True/False format. What could be causing this? Any insight is appreciated.
-Thanks
