Position based selection by attribute values
rakeshreddy0996
i have to select based on position
select based on positions like first position Alpha and second position numeric or first two alphabets and last numeric
HSNAFD151212114A15A10ABBAC501D1D2D5D
is there any possibility to select yellow highlighted vales based on above parameters
Thanks in advance
Best answer by danullen
To select the yellow values I would use a Tester with two lines of Contains Regex:
^\\d\\d[A-Z]$
^\\d[A-Z]$
The first regex says "from start of string (^), two digits (\\d\\d) followed by one capital letter ([A-Z]) and nothing more ($).
  • September 6, 2019
^\\d\\d[A-Z]$
^\\d[A-Z]$
Forum|alt.badge.img+35
  • September 6, 2019
A string searcher with the following regular expression (match 1 or 2 digits followed by 1 letter). Features that match the expression exit via the matched port
^\d{1,2}[A-Z]{1}$
  • September 6, 2019
^\d{1,2}[A-Z]{1}$
I was a bit uncertain about which other accepted combinations might appear in the OP's data, but if it's only these two variants then egomm's solution is of course slimmer and more direct.
gio
Forum|alt.badge.img+15
  • September 6, 2019
^\\d\\d[A-Z]$
^\\d[A-Z]$
@egomm @danullen
@rakeshreddy0996 said "first position Alpha and second position numeric or first two alphabets and last numeric "
Wich is (literaly)
^[a-zA-Z]\\d.*$
and
^[a-zA-Z]{2}.*\\d$
You guys answer selection shown in the picture, which is not in accoredance with the question....
(or you can say this issue has 2 questions)
Also:
^\\d{1,2}[A-Z]$
Splitting in 2 regexps is not necessary.
The last {1} is superfluous.
  • September 6, 2019
gio wrote:
@egomm @danullen
Wich is (literaly)
^[a-zA-Z]\\d.*$
and
^[a-zA-Z]{2}.*\\d$
Also:
^\\d{1,2}[A-Z]$
Well, the last part of the question said "is there any possibility to select yellow highlighted vales based on above parameters?" so that's the question we've answered :-)
gio
  • September 6, 2019
@egomm
@danullen
Almost...;)
For he says, note the bold part...:
is there any possibility to select yellow highlighted vales based on above parameters"
The answer would be : "NO"
  • September 6, 2019
Yes, the question and the example wasn't in accordance as I saw it, so I went for the example and thought I'd leave a wide open door for the OP's applications of the regex search. I'm a "teach a man how to fish"-kind of guy. :-)
