Hello, I am reading in numerous CSVs which use a comma as the delimiter. However the address field also has commas within it, so therefore it is misaligning the data with its headings.
Is there a way to read in the data and keep the address field in one column? Any help appreciated.
dustin
Forum|alt.badge.img+30
  • April 4, 2023
Could you attach an example of your data?
geomancer
Forum|alt.badge.img+48
  • April 4, 2023
When the delimiter is also a character used in the values, these values should be enclosed in the CSV in double-quote characters:
Some string123"North Road, Eastern Village"456
If the double-quote characters are missing, we may be able to add them in FME, but to do this it would really help to have a sample of your data.
