DWG - open, transform, write - layout (paper space) issue
  • February 29, 2016
  • 6 replies
  • 32 views
I'm using FME 2016. My workflow is:
- open dwg
- transform (coordinates)
- write dwg
With FME 2016 I'm able to retain layouts but here is my problem: layout viewports don't seem to be transformed. After the coordinate transformation is done the viewports still point to where the data was before the transformation. I enabled "read paper space layout Information" and "read model space entities through viewport".
Does anyone know if transformer works an viewports as well and if so, how?
Thank you, Rob
Bumping this as we are having the same issue!
jneujens
  • September 8, 2017
For all I know, features having the attribute 'autocad_viewport_handle' can be tricky to write back to DWG. But I don't have any DWG files with viewports to test on. It would be helpful if you could share a sample dataset and/or your workspace?
jneujens
  • September 8, 2017
This article might also give you relevant information...
https://knowledge.safe.com/articles/34345/working-with-autocad-layouts.html
danilo_fme
Forum|alt.badge.img+41
  • September 10, 2017
Could you send us the log file and template workspace ( .FMWT ) ?
  • September 11, 2017
Thanks for your reply @jneujens!
os-local-transformation-test.fmw
hfp-pjv-1-dr-c-0208.dwg
Thanks for your reply @danilo_inovacao
Apologies, but where would I find those files?
