Hello,
We're experiencing issues with google sheets v4 writer adding large amounts of blank rows to the bottom of google sheets. It eventually causes the writers to fail due to size.
Thank you!
Robyn
Hello,
Thank you!
Robyn
Best answer by rharte
I actually figured out the answer to my question after posting! In the Google Sheet V4 Writer, under sheet options, I had to change the setting for Insert Method from Insert Rows to Overwrite. That solved the empty row problem.
Thank you for following up.
Robyn
