Good day.
I faced the problem with running jobs on FME-Server. Periodically (not always) jobs are crashed with status message: "The Workspace requires Python version %0, but Python version %1 is already loaded". I absolutely confused, because if I start this WB again the process will be completed successful.
ArcGIS and FME-Server installed on this machine together and as the custom python the Esri ArcGIS Desktop (Python 2.7) selected.
Who knows how to overcome this problem?
Thanks in advance.
