Can anyone tell me the CKAN server URL for Open Canada? This is for the CKANConnector.
bruceharold
Forum|alt.badge.img+17
To create a web service for CKAN connecting to the Open Canada server, I have tried various permutations around https://open.canada.ca/data/en but no luck. Thanks!
debbiatsafe
Forum|alt.badge.img+20
Hello @bruceharold​
https://open.canada.ca/data/en appears to be the correct CKAN domain name as noted in this page. Actions such as List Resources and Download Resource does appear to work correctly based on my tests. However, the List Datasets action returns no results.
The CKANConnector uses the current_package_list_with_resources endpoint to list packages. This endpoint does not appear to list any packages on the Open Canada CKAN instance in CKANConnector, HTTPCaller, and web browsers.
bruceharold
  • May 3, 2023
debbiatsafe wrote:
Hello @bruceharold​
Thanks Debbi!
