Hi @danilo_inovacao, the FME Objects API doesn't have any capability to read and create an FMERaster object from a raster file path, except a case where you read a raster feature from a file using an FMEUniversalReader object.
If the input feature has a raster geometry, this script works to clip the raster held by the input feature and update (overwrite) the geometry of the feature with the clipped raster.
# PythonCaller Script Example: Clip a Raster# Assuming that the input feature always has a raster geometry.import fmeobjects
classFMERasterTools(object):definput(self, feature):# Clipper's extents.# Modify these values appropriately according to the requirement.
xMin, yMin = -97.6864, 30.3571
xMax, yMax = -97.6802, 30.3509# Retrieve the geometry (FMERaster object) from the input feature.
raster = feature.getGeometry()
# Create an FMERasterTools object.
rasterTools = fmeobjects.FMERasterTools()
# Clip the original raster by the specified extents.# The FMERasterTools.clip() method returns a clipped raster.
newRaster = rasterTools.clip(xMin, yMin, xMax, yMax, raster)
# Set the clipped raster to the feature.
feature.setGeometry(newRaster)
# Output the feature containing the clipped raster.
self.pyoutput(feature)
See also the FME Objects Python API Documentation.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
