scripted parameter question
gio
Forum|alt.badge.img+15
Hi Guys, yu, its met again.
I have a question.
If i do this
$(DestDataset_CSV)  as a scripted parameter and tcl script:  $FME_MacroValues(Outputdir)\\\\$FME_MacroValues(csv_name).csv (just a simple concatenation)
Then $(DestDataset_CSV) ends up like  Outputdir\\csv_name
the extension is missing.
Only when i add this extension to $FME_MacroValues(csvl_name) =filename.csv
i get Outputdir\\csv_name.csv wich is correct.
Why is this?
(in this case i wanted the user not to have to enter the extension, though i changed my mind on that point already..;)
Also i have boiled down the issue by Robbie B
Creating dynamic attributes per "fme_basename"
to just this
It consist of 3 workspaces, 2 of wich have callers, an intricate parameter construction, 2 startups and one shutdown script.
Now one can pick a directory and read files and their attributes straight to (in this case) excell.
I think this workspace might inerest you all because it shows a workaround on the issue of dynamic attributes. No exposing is required.
Check out Robbie B's question jun 18
  • June 26, 2014
Hi Gio, sounds strange. I was not able to reproduce such a situation - FME 2014 SP2.
How about requesting Safe support with the workspace reproducing the problem?
Takashi
gio
  • June 26, 2014
Hi Takashi,
The issue is in fme2013 sp2.
We have tested 2014 sp2 and it ready for packaging.
But i have made a clear argument to not packaging FME:
a simple script packaged run 30% slower on a 8core  16Gb system compared to a unpackaged on a singlecore 3Gb system.
Packaged is 30% slower on a singlecore system compared to unpackaged on this same ssingle coreystem.
So im waiting for it with great anticipation.
