Multiple CSV with different structure to SHP (dynamic way)
Hello
I have 150 CSV files. I would like to convert them to equivalent SHP files. I don't want to do it one by one of course hence I chose dynamic workflow. This should be just a mirror translation (with geometry creation from WKT along the way). But I can't get this to work.
In the writer I tick the Dynamic Properties with Schema Sources set to "*.csv [CSV2]" but this doesn't create any shapefiles complaining: 'Features with no schema defined'
When I untick the Dynamic Properties the shapefiles are created but only with the geometry, no attributes.
Here's the workbench. The CSV filename is the name of the feature. Bunch of attribute renaming and removing. Creating geometries.
Reader:
Writer (I tried geometry defined by schema as well but same result):
Am I missing something?
Thanks!
Best answer by takashi
I suspect that the feature type name has been set to "CSV" (format name).
The CSV reader gives the format name "CSV" as "fme_feature_type" attribute to every feature by default, and the source schema definition will be identified with the "fme_feature_type".
In your writer feature type setting, you intend to identify the source schema definition with "Default from Shapefile name above" i.e. the source file name, but the writer won't do it if the actual source schema definition name (i.e. fme_feature_type) was "CSV".
If you want to use source file names to identify source schema definitions, you have to set "From File Name(s)" to the Feature Type Name(s) parameter when you add the reader to the workspace.
You can then use the "fme_feature_type" as the destination feature type name (Shapefile Name = Schema Definition Name) in the dynamic writer feature type.
Hi @gonzikcz
What if you set it to "Schema From Schema Feature", does that work?
  • December 9, 2017
  • December 12, 2017
Hi @takashi
Yes, that fixed it. Thanks for the tip! However, I wonder how is this different from the filename_extractor which returns exactly same table name?
Cheers, Jan
  • December 12, 2017
jlutherthomas wrote:
Hi @gonzikcz
Hi @jlutherthomas
I tried this one too but the result was the same. This was my first try of dynamic flow but from the documentation I understood that this option is for different cases.
Thanks, Jan
  • December 13, 2017
The schema definition is identified by its unique name (Schema Definition Name), and the name is equal to the value of "fme_feature_type" if the source schema has been read from a source dataset by a reader. Note that "fme_feature_type" is not always equal to the source file name.
In your original workspace, "fme_feature_type" had stored "CSV" (format name) according to the reader parameters setting. It's a case where "fme_feature_type" is not equal to the source file name. Nevertheless you had set the source file name to Schema Definition Name in the writer feature type. It's the reason why the dynamic writer was not able to recognize the schema definition.
  • December 13, 2017
I see. Thanks for the great explanation!
